[業界要聞] New Essence Electrostats Are A Game-Changer; Dazzling Industrial Design Debuts
bobrapoport 發表於 2014-3-25 03:11:15 |已閱:39241|評論:0| 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式 來自 美國
March 23, 2014, St. Petersburg, FL, USA......The first time you see Essence is a like Falling in love, your eyes are dazzled by Their Beauty. One Special Look and you New Essence Electrostats Are A Game-Changer; Dazzling Industrial Design Debuts Essence 1200 NewShoot1 (3).jpg
know  something is going on, th New Essence Electrostats Are A Game-Changer; Dazzling Industrial Design Debuts electrostatic-transducer-movement.png ey're Transparent, you can see through them.   The question is, How do They work?
Instead of the big ugly boxes that Color Distortion sound with resonance-induced, Essence ™ Electrostatic Speakers reproduce sound in a revolutionary new Way Speaker cabinets without expensive, woofers, tweeters, or  crossovers.
Essence ™ speakers use a single ultra thin (4 microns) low-mass film diaphragm suspended in an electrostatic field where a simple law of nature makes sound. Like forces repel and opposite forces attract to move the air faster than any conventional speakers can, with just one moving part.
The diaphragm is lighter than the air its moving, 50 to 100 times lower in weight than big woofer cones that have to overcome their own inertia. A speakers ability to stop and start as fast as the actual music is what determines how clean the sound will be. Electrostats outperform dynamic speakers by their ability to accurately track your high res music sources.
Featuring the first transparent acrylic stator assembly in audio history and using the latest 3D printed electronics Essence ™ Electrostats cleverly increase the excursion of the diaphragm in the low frequencies to move twice as much air as any previous electrostat in the same price range. The result is full range performance without the need to resort to a dynamic woofer and crossover in a box behind the panel. They are wall-mountable and look right at home with a flat panel tv.
Fast Facts: New Essence Electrostats Are A Game-Changer; Dazzling Industrial Design Debuts Essence-1200-Side-view-93x300.jpg
  • No Woofers, No Boxes, No Amps, No X-overs
  • 48.8 "H x 11.38" W x 1 "D (1200mm x 250mm x 30mm)
  • ± 3 dB 48 Hz to 23 KHz
  • 4 Ohms, 88 dB efficiency
  • 26.5 lbs each (12 kg.)
  • Wall Mountable
We are looking for a goo distributor or dealer in Taiwan, please let us know if thats you.
Bob Rapoport, VP Sales and Marketing
727-580-4393, bob@essenceelectrostatic.com
Skype: Bob.Rapoport New Essence Electrostats Are A Game-Changer; Dazzling Industrial Design Debuts Essence small logo trans.png
GMT+8, 2025-12-6 02:07 , Processed in 0.540525 second(s), 41 queries , Gzip On.
