Logos 1N規格:) s$ j3 d% G: V7 O; S) S
· Digital input; ~4 g( P) \ {
· ON/OFF switch% `$ x% F$ r4 k. S9 t* v$ G
· Orange locking led# C* Y. ~5 @4 d* m }2 Z
EFFICIENCY, I. |9 Z' A0 Z2 F0 ^- O
· 89.5 dB
, ~; e' j5 K7 M7 F# O8 y( wBANDWITH1 V' |7 n. `2 v$ X7 i2 I8 p0 `: E& a
· Low Frequency Cutoff: < 40 Hz -3dB: B: _ x- u& u8 U6 R+ H
· High Frequency Cutoff: > 28 kHz9 _# X* q9 w) i& I# D, E
DRIVERS) g/ S _) u, R" V
· 1 x 17 cm low frequency proprietary driver
$ U& O) L& e* ]( ~2 _) g" R· 1 x dome tweeter
2 R- t3 g4 h! l3 VBASS LOAD
" Z" g2 b; d) w. l% X· 2 x Flexible Vent loading
' ^- X1 W' O T. G3 {AMPLIFIER
. R `( |! l" Y* T' _, r· Buit-In 2 x 100 W Telos Amplifier# D$ f: D: H3 @3 r( o3 x3 m
· Amplifier dynamic Range: > 100 dB (no weighting)
4 b' D6 i) P; U* q$ n/ XVOLTAGE0 r+ R$ J$ p: r9 r |3 L3 N1 n
· Nominal range: 117V or 234V (+/-10%)) D6 ^9 N$ a8 |+ R
· Internal Fuses:9 Q( M3 X S3 ^
- 5A slow-blow type for 220V" w8 \$ G! c3 d( d0 R- C: F
- 8A slow-blow type for 110V
$ C3 c2 Q4 N6 m- n! JSIZE AND WEIGHT+ l6 _5 y3 K3 N, {. S
· 23 W x 33 H x 38 D (cm) - 23 kg net i# K a8 _2 c% m, O
2 Y+ ^' o6 h7 W
Logos 2N規格:3 t {; w2 Z V, [0 w6 j- \. n
· Digital input
- U$ i6 `3 G i· Digital output
/ }5 {5 J) H5 v: r) \· ON/OFF switch
0 q8 f& L/ @& F* I8 Y· Orange locking led6 {5 k5 S, q, r# ?- I9 ^
· Output power line voltage connector to power the Logos 1N (Logos Frame)/ d; Z1 }) h A G0 Y' L7 D
FREQUENCY RESPONSE
9 F7 f$ R& C! K" H# @· Frequency response: Low Frequency Cutoff: < 22Hz -3dB1 a+ F; {% T# v/ m5 P
DRIVERS8 n0 B q. c: A' f* r
· 30 cm driver and 30 9cm passive radiator, selected for its high linearity and dynamics L9 L8 Y& @; Z( C1 x T# [$ l
AMPLIFIER0 E( N* j% F* T
· Buit-In 2 x 100 W bridged Telos Amplifier
% M3 i% i0 b2 |· Amplifier dynamic Range: > 100 dB (no weighting)% P) }( m. g! u- Q( K2 `7 `
VOLTAGE) ~0 u/ f" s& ~2 D
· Nominal range: 117V or 234V (+/-10%)8 `3 T% Z% v4 w5 q# U4 a3 ^8 T
· Internal Fuses:4 B; M9 ~6 ]' o; \( G7 E
- 5A slow-blow type for 220V1 q O, _2 v3 B9 D! ?2 Z) C
- 8A slow-blow type for 110V) Z/ n: d g4 o. W$ Y' J
SIZE AND WEIGHT8 u3 m& T8 _0 Y* Y2 V
· 36 W x 48 H x 51 D (cm) - 50 kg net
4 Y6 L5 s1 n, s. d6 g& b4 E/ L( O0 \* k- _! @4 t7 h( c0 ]
